Washer agitates slowly
Hi, My washing machine agitates very slowly and sometimes not at all. If it’s a small load it may make it through the cycle while agitating very slowly, and not with much force. Usually with not enough force to pull the clothes thru the agitator. If it’s a heavy load it will usually stop agitating, if it starts at all. It spins fine if this helps. Thanks for your help.
You probably have a worn out drive block. Grab the agitator by the neck and yank it out Hulk Hogan(get mean). The drive block will be right there. The splines wear out and it won’t wash worth a dang.
[ATTACH]791[/ATTACH]Part# WH43X10009
