I have a Frigidaire/Electrolux FFHT1826LB0
For the past three or so months, the refrigerator has seemed to be running much longer than it normally does, though it was not getting abnormally cold.
Last week the freezer door was knocked open by off balance food, and when I found it the next morning, a good deal of the freezer had thawed, and ice crystals were all over the food in the back.
I cleaned up the mess, rearranged and closed it.
Now it seems like the defrost timer isn’t turning off for a cooling cycle. The refrigerator will run for about 3 minutes, and then turn off for about 5 minutes, then run for 3 minutes again, repeatedly. (This is a slightly longer run duration, now that I have cleaned the condenser coils.)
As far as I can tell, the motor is not overheating. It is hot to the touch, but not uncomfortably so. There is a clicking sound relating to the power cycling, and it seems to be coming from the back right side, somewhere near the freezer. That is the general location of the Defrost thermostat, as well as the defrost timer.. however, I can’t see any easy way to access the defrost timer.
Any ideas are welcome, I don’t cherish the idea of taking the entire refrigerator apart, but that only more so than buying a new fridge.
