Brand: whirlpool Model Number: wrsf3036tz Main Symptom: refrigerator does not cool nor freeze What happens & when: refrigerator had functioned fine before moving it to a new home and then storing it in a garage. after plugging it in, it runs but doesn’t get cold.
Remove the lower evaporator cover while the fridge is running and look at the frost pattern on the evaporator coils. A light layer of frost over most of the surface of the coils indicates a properly operating sealed system. If there is only patchy frost, frost at one end or no frost then suspect the sealed system. Un plug the fridge, remove the rear access cover and inspect that there isn’t a large build up of dust, no debris in or around the fan, condenser coils or compressor. Examine the wiring carefully for loose connections, damaged wires or broken wires. Once those checks are done plug the fridge back in and ensure the compressor starts & that the condenser fan kicks on and is turning freely and moving air. If after these checks the fridge doesn’t cool then there is probably a sealed system issue
