Wall heater 349581512 wiring
Brand: sears roebuck
Model Number: 349581512
Main Symptom: wiring from unit to house electric.
There are two wires, both black, coming from wall forced fan heater Are these two wires dedicated to neg and pos?
On your Sears Roebuck wall-mounted fan heater, model 349581512, the two black wires are not necessarily positive and negative.
Most household heaters operate on AC voltage, so they don’t have positive (+) and negative (−) connections like DC-powered equipment.
However, we need to determine whether your heater operates on 120 or 240 volts before connecting anything.
  • 120-volt heater: Typically uses one hot wire and one neutral wire.
  • 240-volt heater: Typically uses two hot wires, with no neutral required.
  • Ground wire: The heater’s metal housing must be properly grounded.
The fact that both heater wires are black doesn’t tell us which electrical connections they require.
Here’s what I’d recommend:
  1. Turn off the breaker supplying the heater.
  2. Look for a rating label showing 120V, 208V, or 240V.
  3. Check for a wiring diagram inside the heater’s electrical connection compartment.
  4. Don’t connect either black wire to neutral or ground until the wiring requirements are confirmed.
One question: Can you tell me whether the heater’s rating label says 120 volts or 240 volts?
If you can send a picture of the label and the two black wires, I can help you identify how they’re supposed to connect.
