Volute removal
I have a Kenmore/Whirlpool dishwasher 665.16972201. My motor assembly is leaking from inbetween the metal motor case and the Volut back. I think that the seal, which looks a little like an O-ring, and sits between the impeller and front motor case is leaking. When looking in between the impeller and the Volute back it appears to be distorted and possibly torn. I cant seem to figure out how to get the impeller and Volute back off of the shaft so that I can remove and replace the seal.
This may help
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
that worked. thanks,
