Viking Range VGIC53014BSS03 Oven won’t start
Brand: Viking Range
Model Number: VGIC53014BSS03
Main Symptom: Oven ticks but won’t start.
What happens & when: oven will tick but won’t start and keep a flame
Hey Matthew, if it is sparking and not lighting, it could be the gas valve. You have a spark ignition system, if a flame is not detected the spark module sees that and usually stops sparking. I would look at the valve that sends gas to the burner as to being the issue. I don’t have any technical material on the Viking products to share with you.
