Viking Dishwasher Problems
[FONT=‘Times New Roman’,‘serif’][COLOR=#000000]I have a viking dishwasher - VUD040. The unit stopped spraying water. I replaced the impellor (which was needed). It ran fine for 2 full cycles, then started having problems again. This time, when its turned on, the unit never never advances out of the initial stage (not sure, but I believe its the drain pump running). The knob advances thru the full cycle, but the unit just makes the louder pumping noise the entire time and never rinses or cleans (the soap tray does come open). I then replaced the main timer unit (located right behind the cycle selector knob). It ran fine for 1 full cycle, then started having the same problem again. I don’t know if I got a defective timer or there is some other sensor or switch thats causing the problem. Any ideas?[/COLOR][/FONT]
[FONT=‘Times New Roman’,‘serif’][COLOR=#000000] [/COLOR][/FONT]
Check to see if water is leaking into the drip tray underneath the dishwater. There is a float that will shut off the incoming water if enough water accumulates in the drip tray, and it doesn’t take much!
