I have an ancient Trane furnace/ac unit (inside gas furnace with cooling evaporator above that, outside air conditioner/compressor unit). The inside box(es) have the air handler/blower - that blower’s motor is switched by a 24VAC relay driven off a transformer that also sends 24VAC to the thermostat and outside contactor (relay) coil.
Anyway, this all works. Can turn on the fan switch on the thermostat and the blower runs, can turn on cooling and the outside contactor does its thing, the whole nine yards.
But…
The 24VAC relay’s coil (standard 90340 style: image search for “90340 relay” to see lots of images of it) gets extremely hot - WAY too hot to touch. So, being naive and figuring there might be some sort of internal short in the relay’s coil, I just replaced it.
The replacement relay is getting WAY too hot to touch.
The specs for the relay say it’s 10VA for the coil. I believe that (~6W?) suggests the wattage could be enough to heat up the thing, maybe quite a bit.
But still…
Is this extreme temperature normal behavior for an otherwise working fine air handler relay/relay coil?
If not, where could I look to find what’s causing the current draw/heating through the relay’s coil? (I removed the relay, cleaned its plugs, and replaced it - same heat; I also checked the voltage across the coil and it was ~24 VAC so no short from wall voltage/current)
One of the next steps (to just prove to myself that this IS normal) would be to simply unplug the relay and wire JUST its coil to the transformer to prove that it is indeed the coil that’s causing the heat (that is, disconnecting the relay completely from everything other than the coil connection).
But I thought I’d check here first.
Anyone seen this? Anyone have a quick answer? Procedure?
Thanks very much for any feedback.
