Vent Hood Repair
No power on entire hood after electrical storm. No blown circuit break on house panel so suspect blown fuse in vent hood, but can’t locate the fuse. The parts blow up is no help at all, nor are the owner’s manual or installation instructions that came with the hood. Can anyone tell me where the fuse is located ?
Click for parts breakdown.
Click for fuse.
The fuse is # 170 on the diagram and will probably be located inline between the power supply block and the control board/area.
Chances are there is no fuse on your vent hood. if your sure its burnt…its not costly to replace.
