I cleaned the screens out of the inlets but the cold water trickles out , when you switch it to warm works fine and rthe hot also works fine, do I need to replace the water inlet valve?
If you’ve cleaned he screens and its still not working right, it will need to be replaced. Part W10364988
Whirlpool W10364988 Water Inlet Valve Assembly - AppliancePartsPros.com
