Brand: GE Model Number: GDT655SGJ0BB Main Symptom: User interface controls do not light up What happens & when:
I had contacted you in August about the user control panel being unlit and non-responsive. Since this had happened before, I had already purchased and installed a new main control board. You explained the meaning of the different states of the LED light. The LED was steady on.
You then explained that there should be 13.5 VCD coming out of the main board. I was not able to continue with troubleshooting until now. Using pins 2 and 5, I verified that 13.5 VCD was coming out of the main board.
After taking the door off and apart, I checked the plug to the UI board which also showed 13.5 VCD. So I purchased a new UI board. After installing and putting the door back on and plugging the door harness into the main board, the LED light on the main board flashes 4 times, pauses, and repeats. The only light on the UI that is lit is the “Clean” light. None of the other buttons on the UI light up. Could the personality/configuration jumpers not be set correctly?
Yes, the personality or configuration jumpers on the new user interface board could definitely be causing this issue, especially since the symptoms changed after replacing the UI.
The good news is that you’ve already done some excellent troubleshooting. You’ve confirmed approximately 13.5 VDC at both the main control board and the UI connector. That tells us the low-voltage supply is reaching the door.
The fact that the main board LED now flashes four times and only the Clean light illuminates suggests we should check the new UI’s configuration and communication with the main board before replacing anything else.
Here’s what I’d recommend next:
1. Check the personality jumpers. Unplug the dishwasher and inspect the new UI board for configuration jumpers. If the replacement board uses jumpers, they must be configured for your specific model, GDT655SGJ0BB. An incorrect configuration can prevent the controls from operating properly. Don’t change them randomly.
2. Check the replacement part number. Verify that the new UI board is the correct replacement for your model. Some GE replacement boards look identical but require different configurations.
3. Inspect the communication harness. Since you’ve already confirmed 13.5 VDC at the UI, inspect the remaining wires and terminals between the UI and main board. Having the correct supply voltage doesn’t necessarily mean the boards are communicating.
4. Reset the dishwasher. After verifying the configuration and reconnecting everything, restore power and allow the controls to initialize. Check whether the buttons respond.
One important detail: The four-flash pattern may indicate a communication or operating-state condition, but I wouldn’t identify it as a specific fault without confirming the diagnostic information for this control board.
I have two questions:
What is the part number of the new UI board you installed?
Did the new UI board come with configuration jumpers already installed, or were you instructed to transfer or adjust them?
Answers to your two questions. Part no. is WD21X31902C. New UI board had 4 jumpers all set on both pins. No instructions with part. I noticed old UI board had no jumpers or pins. ???. I looked up APPs video and found the personality setting was 11 for GDT655. So 8,2, and 1 jumpers all on both pins. 4 is not.
Put everything back together. Now, I am getting 4 flashes and a pause on main board LED repeatedly. UI board lit up but not responding. Start light is blinking. “Lower” wash zone light is lit. Lock control light lit. 49 on cycle minutes.“Light” cycle light lit. Center amber light flashing as if cycle interrupted. No other lights.
Thanks for the detailed update! This is actually some progress on your GE dishwasher, model GDT655SGJ0BB. Previously, the user interface was almost completely dead. Now the new UI board is lighting up, which tells us something has changed.
However, the combination of the 4-flash main board LED, blinking Start light, illuminated Control Lock light, and unresponsive buttons suggests we still have a communication or configuration problem.
I wouldn’t purchase another board just yet.
1. Double-check the personality jumpers
You installed UI board WD21X31902C and selected personality setting 11 using jumpers 8, 2, and 1.
Mathematically, that is correct:
8 + 2 + 1 = 11.
But we need to confirm two things:
Personality 11 is correct for your exact model and UI board revision, not just the GDT655 series.
The jumper positions match the instructions for WD21X31902C.
The fact that your original UI board had no jumper pins isn’t necessarily a problem. GE uses different board designs, and replacement boards may have configuration options that the originals didn’t.
2. The four flashes may actually be normal
GE’s service information identifies four flashes within approximately three seconds as a paused cycle, not necessarily a communication failure.
That fits your blinking Start light and flashing amber indicator. The dishwasher may be remembering an interrupted cycle.
3. Try these steps next
Turn off the dishwasher’s circuit breaker for 5 minutes.
Restore power and wait about 30 seconds.
With the door open, press and hold Start/Reset for approximately 3 seconds to cancel the interrupted cycle, if the button responds.
Allow the cancellation to finish.
Try pressing the Cycle Select button to see whether the displayed cycle changes.
If the controls respond, select a cycle, press Start, and close the door promptly.
If the Control Lock indicator remains illuminated, try holding the button marked Control Lock for approximately 3 seconds. On some versions, that function is shared with another button.
4. If the buttons still don’t respond
Turn off the breaker again and inspect the wiring harness between the UI and main control.
You’ve already measured approximately 13.5 VDC at both ends. That’s good, but it doesn’t prove the communication wiring is intact.
Check for loose connectors, bent terminals, or damaged wiring where the harness passes through the door. A harness problem can cause similar symptoms even with proper supply voltage.
Appliance Parts Pros
Two questions that will help narrow this down
When you press and hold Start for 3 seconds, does anything change? Does the blinking light stop, does the display change, or is there absolutely no response?
When you watch the main board LED, are the four flashes spread over approximately 3 seconds, followed by a pause?
I’m leaning toward the dishwasher being stuck in a paused cycle or the controls being locked, rather than immediately suspecting another failed board.
The fact that the UI now displays 49 minutes and several cycle indicators is encouraging. Let’s see whether we can get it to respond before taking the door apart again.
After determining the wiring harness did not show any fraying, I unlocked the controls. I was then able to hold the Start button to cancel the cycle. I loaded some dishes and ran a Normal cycle. It completed with no problems. It didn’t occur to me to unlock the controls previously. I also wonder why the new UI board put the dishwasher in the middle of a cycle. Oh well. It’s working now. Thanks for all of your knowledge and advice Jeff.
