Upright Freezer
Brand:Frigidaire
Model Number:FFU21M7HWN
Main Symptom: Door wont seal
What happens & when: Door does not close all the way, there is play when door is locked
Look at the gasket at the bottom, closest to the hinge. Is it bunched up or deformed? Does the door look like it is sagging? These are some things to look at. If the gasket is deformed, replace it. If it is sagging, there may too much weight in the door and you may need to replace the hinge at the bottom.
Replaced gasket, but does not seal at bottom and on the lower (handle side) of door.
