Upper wash arm will always be perpendicular
I can move the wash arm to any position in the dishwasher, shut the door, letting the cycle continue to wash and when I open the door, it will always be perpendicular to the door. Once it gets there, it will not move anymore, but moves manually. Also I don’t think there is very much water coming out of it (not enough to spray). So i tried a solution of CLR for cleaning out the dishwasher. It didnt resolve the problem, so I purchased and installed another middle arm and middle spray arm seal. It still does not work.
Any other suggestions you have to fix this problem would be most appreciated.
Check #6 ‘Chopper’ in this diagram for your model dishwasher. It may need to be cleaned or replaced. If it gets plugged up it will restrict the flow of water to the spray arm.
Pump and motor parts replacement parts for WHIRLPOOL GU1200XTLQ2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
