I am troubleshooting why my wife’s dishwasher because it does not clean and rinse very well. Among other things, I removed the upper wash and rinse arm assembly to clear out any clogs in the passageways and noticed that the vertical part of the rinse arm assembly has an opening on the left side. The area around the opening looks like there should be something attached (clipped) over this opening but there is not. The parts diagram does not seem to show if there should be a plug over this opening or not (see attached).
Is this the way it should be or is a part missing? Further, if no plug or part is missing, what is the purpose of this opening? Is it an air inlet for the tube going to the pump?
Thanks in advance for any info on this.
Upper wash and rinse parts diagram.pdf (158.6 KB)
