Upper section of fridge not as cool as lower section
Brand:Kenmore
Model Number:25360721003
Main Symptom:upper section of fridge is not as cool as lower section
What happens & when:refrigerator runs but not cooling properly
Parts or tests already tried:My thoughts: it appears that there are two vents where the cold air would be blown into the compartment, one in the lower section and one in the upper section. Is it possible that there is a damper not working properly to allow air flow through the upper vent?
The most likely cause for this issue will be a faulty evaporator fan motor which would need to be replaced. You can remove the rear panel inside the unit and test for 120 vac to the fan motor. If there is 120 vac but it is not turning then replaced the fan motor. Frigidaire 5304442620 Freezer Evaporator Fan Motor Kit | Genuine OEM Part
Thank you, I will check that.
