Upon spin, all lights flicker then shuts down, no code
When the washer goes into spin cycle as the RPMs ramp up it seems the vibration sets off something and causes the whole front panel lights to flicker a few times and then the unit beeps and stops everything. The lights stay on with remaining time showing and door unlocks. With nothing in the washer, it of course spins fine and drains appropriately. When I pulled the bottom plate off, I saw that both front shocks were disconnected. One was broken at the top clip. I was able to reattach both of them with ease and they look to be functioning correctly. The rear ones are fine.
  1. The shocks being disengaged could have caused too much vibration over time to cause damage to something up top on the panel or controls. My question, is which is likely the bad part?
  2. If I figure out which part is bad, should I replace the one/both shocks so this does not happen again? I should note, I replaced the bellows a year ago. I’m thinking I must have disconnected them and did not reconnect them to access the drum. I can’t see why I would have done that in my cursory glance underneath today, but who knows.
All fixed. Broken wire in the ribbon cable that runs back. Apparently, this was not run around the upper perimeter in the brackets made for the wire runs. It was sitting loose atop the drum, so over the years, it had vibrated enough to wear through one part of the ribbon cable.
The vibration/flakiness is what got me thinking loose connection somewhere. Glad I actually took the top off and looked. As soon as I moved the front display plate a tad, it beeped a few times. A few more wiggles and some slow chasing down of the break in the ribbon netted me the culprit.
https://www.dropbox.com/s/281k6qoi3gsd9jt/2015-05-21%2012.29.25.jpg?dl=0
A little splice and some tape should remedy it for now.
