Unit dead - kind of
This unit was running and quit when almost done with a wash. The front panel cycle lites will not lite up, and it will not run, but when you press the on/off button with the door latched you can almost hear the motor try and run (I can here a very quick noise. Don’t know if it’s the motor or a solenoid. Today I pressed the on/off switch and it started to drain for a few seconds and quit, but the cycle light did not lite up at any time. Any ideas?
Wil
Sounds like the control module has gone bad. You can use the troubleshooting manual from one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
  • The part number for the control module is AP2804247
Here are the breakdown diagrams and Replacement parts for BOSCH SHU4306 UC/06 (FD 7705-7912) | AppliancePartsPros.com
