The oven under cooks the bottom of cookies, pizza, etc.
Initially it appeared that the bake element was open, so it was replaced. Same symptoms after replacement.
An appliance service man was called and said that the controller needed replacement. I found one on the internet and replaced it. Same symptoms after replacement again.
I ran a test by turning the oven on bake with the default 350 deg temperature. It appears to work OK with nothing in the oven (the broiler and bake elements cycled for about 7-8 minutes with the bake element having a much higher duty cycle). I monitored the temperature with an oven thermometer set on the upper rack in the back right hand corner. Itsa thermal lag caused it to take longer to stabilize at 350 (about an extra 5 minutes after the controller said the oven was ready) to indicate 350 deg. After that, the bake element would cycle with a very low duty cycle (about 30 sec every 4 minutes or so) to keep the temp up. The temperature band is about 10-15 degrees.
When I opened the oven door for one to two minutes, the oven temp dropped about 50 deg as measured on the oven thermometer on the back right of the top rack. The bottom element cycled to bring the temperature back. The broiler element cycled with a much lower duty cycle than the bake element.
I am looking for suggestions of the the likely causes and/or procedures to find the cause of the under cooking of the bottom of pizzas, cookies, etc.
