Brand: Kenmore Series 80
Model Number:110.82983810
Main Symptom:Unbalanced Tub
What happens & when: During Spin Cycle
Parts or tests already tried: Suspension and Balance Springs replaced
The washing machine is 38 years old and I have kept it running with parts from Appliance Parts Pro. Replaced the control dial, water temp switch, dog ears, put in new agitator, and the suspension springs and counterweight spring once before when I had the unbalanced tub in the past and it fixed the problem. Now i replaced the springs but it seems to still wobble when i try to move the tub before running it. Not sure if the tub is supposed to move when pushed from the agitator but seems to move less with new springs.
I purchased the two sets of suspension pads but did not replace. The old ones are still attached. Also the snubber plate is aligned from what I can tell.
Have to try running it. Any thoughts? Is there something that may be broken that I dont see visually? I think maybe its time for a new one, but would like to keep it going as it still did its job.
