Wine cooler will not cool. Coil is clean. Fan works. Compressor runs and gets warm after awhile. Neither copper line from the compressor gets hot or cold. Does a bad compressor run (or hum) if it is bad, or is this a pretty good indication that it only needs charging?
U-Line can be reached at U-Line Service - Welcome to U-LINE Service , OnlineService@U-Line.com or 1-800-779-2547 , if the compressor is running and you have no frost on the cooling plate and the condenser is cool, it’s most likely the system is low on gas and there’s a leak somewhere. If this is the case, there is a five year warranty covering the repair, reach out to U-Line for help.
Other possibilities are a restriction in the system or a non-pumping compressor which is very, very rare.
