The control panel appears to work ok. When I start a cook cycle, the timer counts down, completes the cook cycle, beeps at the end, in short everything behaves like ‘normal’ except the turntable wont turn. food wont heat, and the lamp doesn’t light during the cook cycle. I do hear a bunch of clicks when I start the cook cycle.
Prior to above problem, the microwave used to trip the circuit breaker when the door was opened. After reading through the forum, I diagnosed the problem to a faulty interlock switch which I have since replaced.
I really don’t want to call a GE ‘authorized’ repairman nor do I want to deal with a replacement microwave that matches the existing trim kit
I replaced the top interlock switch (WB24X823). The faulty switch had a short internally (zero ohms always). With the new switch, when door is closed, resistance is infinite while with the door open, it is a few ohms.
