I have installed this model dish water but have no water flow into the tub. I understand there is a water valve that may be turned off on the machine. Where do I find that valve and how do I turn it back on?
Here are your parts includes a wiring diagram.
Replacement parts for DU4500B models | AppliancePartsPros.com
[COLOR=Blue]
Where do I find that valve and how do I turn it back on?[/COLOR]
The valve is Item 2 in Section 6. It is behind the kick plate under the unit.
There are a number of things that can stop water flow.
Easiest way to troubleshoot is with a meter.
Measure across the valves contacts when it should be filling.
If you see 120 volts either the valve is shot or the filter is clogged.
If no voltage
With power removed from the unit, check the overfill switch for resistance, should be 0 ohms. If not then either the float is hung up or the switch is shot.
If all OK then probably the timer is shot or one of the wires from the timer to the valve is broken/open. You can also check this with a meter by measuring from the power Neutral side of the valve (white) to the timer side of the overflow switch, should be 120 volts.
Here is a good site with troubleshooting help
http://www.applianceaid.com/dishwash.html
sounds good to me :)
