Can I turn my dryer door around so it opens from the other side? It is a Neptune Gas Dryer, the screws look like they line up for an even switch?
Hi Linda
Should be very easy, look at page 16 on the service manual.
Oh, you don’t have the service manual? Well here it is. (Maytag gives this as the manual for your dryer even though the manual does not list your model number)
http://www.servicematters.com/maytag_library/docs/16025911.pdf
Good luck, let us know if you need any more info.
