tub seal
it was made in 2000.i took washer completely apart .my problem now is i dont remember how the tub seal came out i left the part in on the bottom of tub i have a rubber part with spring inside and a brass and rubber type washer i don’t remember if washer went on first or rubber with spring :mad:in the parts diagram shows or looks like rubber boot part then the washer on top,but shows on transmission and i know took out of tub and it brass part of washer go up or down
I don’t know if this service manual will help as you have an older model.
http://www.emaservicetips.com/pdfs/489_5.pdf
Check it out, your machine is made by electrolux and is a basic Frigidaire machine.
sorry was out of town couple days! i bought a repair book its no help as far as how tub seal goes thanks’
