Tub is making noise
Brand:GE
Model Number:GFW450SSM1WW
Main Symptom:tube is making noise in spin
What happens & when:in spin
Typically, when you have a grinding noise in the spin cycle, this will be caused by the bearings. The only way to get the bearings for this unit is to get the rear outer tub. Unfortunately, it has been discontinued by the manufacturer with no suitable replacement available. WH45X22914 Rear Tub Asm | Genuine Ge OEM In Stock
