So I’m trying to reverse the doors on this unit. The manual says it can be done and walks me through it, but there are only hinge holes on 1 side of the doors. The manual model # matches my fridge model #, so is it possible that the manual is just wrong? Or am I missing something.
[COLOR=“Blue”]The manual model # matches my fridge model #, so is it possible that the manual is just wrong?[/COLOR]
I would say that the manual is incorrecct.
Often they will use the same manual to cover a number of different units and then in the fine print put “some units” or change somethings on the machine without updating the manual.
[COLOR=“Blue”]Or am I missing something.[/COLOR]
I doubt that you are missing anything.
If they were there you would see the hole plugs.
If the holes are not there you are out of luck.
