I’m trying to replace the igniter switches on my GE Stovetop but have no drawings to go by. I can’t even figure out how to open the unit to get to the switches. Don’t want to randomly start removing screws. Any suggestings/help?
In order to access the ignition switches you have to remove all burners and the top panel.
- The part number for the ignition switches assembly is [COLOR=#0066cc]AP3185909[/COLOR]
Here are the break down diagrams for the GE stove Model JGP932BEC1BB
Thanks for the info. One other question. I see that the burners have 2 screws each but are also held down by the igniters. How do you remove the igniters(#154 in the drawing)?
Part #[SIZE=2]AP3185909[/SIZE] ([SIZE=2]WB18T10176)[/SIZE] isn’t the correct part. Attached is one of the switches from the existing harness. I guess I’ll be contacting GE directly to see if there is a recall. I have had continous problems with this unit almost from the beginning. Why they would have a non-waterproof switch virtually exposed to the cooking surface is beyond me!
_0326101629_001.pdf (1.4 MB)
