Brand: Amana
Model Number: NTW4516FW4
Main Symptom: Stops on rinse cycle if I don’t reset computer
What happens & when: I have already ordered a control panel from you and replaced
Is the unit filling at the rinse cycle? If it is not then check to make sure that the valve is getting 120 vac to it. If there is 120 vac to it then check to make sure that the screen is not clogged and if not then replace the valve. If the valve is good but not getting power then replace the control board.
Just put in a new control board that I ordered from you. It runs fine after I reset the control panel.
I have to reset the control board before every load of wash.
