Troubleshooting a Kitchenaid circulation pump
The circulation pump on my kitchenaid (KUDP01FLBT3) is not working. The washer seems to cycle through the rest of the cycle well enough - filling, draining and drying, but does not pump water through the wash arms. After the tub fills and heats, the pump does not turn on. Just wondering if its possible that there may be an issue other than pump motor and if there is a way to more accurately troubleshoot that before I plunk down $140 for a new pump assembly. Thanks!
Check for 120 VAC to the pump motor while the control calls for wash.
If there is proper voltage, replace the motor.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=513233
