Trouble shotting a Maytag Water Level Switch
I have a problem with the water level settings on a Maytag washer, model lat8216aae. The selector for the water level settings has 4 levels, mini, medium, large and super. When set on mini the tub fills to 1/2 - 3/4 and when set to medium it fills as if set to large. I was looking for some advise on how to trouble shot this problem.
Empty the washer. Open the control panel and remove the front panel. Disconnect the pressure hose from the water level switch and form the tub. Make sure everything is clean and the hose is not broken. Reconnect the pressure hose on both ends and check the washer. If it did not help then the water level switch has to be replaced.
  • The part number for the water level switch is AP4026928
Here are the break down diagrams for the Maytag washer Model LAT8216AAE
