Brand: jenn aire
Model Number: jfc2089hes
Main Symptom: trisensor climate control unresponsive
What happens & when: I cannot change the temp and none of the other buttons work
Hi! If the TriSensor Climate Control panel on your Jenn-Air JFC2089HES refrigerator is completely unresponsive and you can’t adjust the temperature or use any of the buttons, the problem could be with the control panel itself, its wiring, or the main electronic control.
Before replacing anything, I’d try a couple of quick checks.
1. Reset the refrigerator
- Unplug the refrigerator or turn off its circuit breaker.
- Leave the power off for about 5 minutes.
- Restore power and wait for the display to come back on.
- Try adjusting the refrigerator and freezer temperatures.
If the buttons start working again, the control may have temporarily locked up.
2. Check whether the display is working
This will help narrow down the problem.
- Display is lit, but none of the buttons respond: The keypad or user interface may have failed.
- Display is completely blank: There could be a power supply problem, loose connection, or failed electronic control.
- Only certain buttons work: This points more toward a keypad problem.
3. Check the control panel connections
If resetting doesn’t help, unplug the refrigerator and inspect the wiring connections behind the TriSensor control panel at the top of the fresh-food compartment.
Look for loose connectors, corrosion, moisture, or damage to the keypad ribbon cable.
If everything looks good, I would suspect the touchpad/keypad assembly first, followed by the display control board. These are separate components on this model, so I wouldn’t replace both without further testing.
JustAnswer
+1
A couple of questions
- Is the temperature display still lit and showing numbers, or is it completely blank?
- Is the refrigerator still cooling normally, even though you can’t change the settings?
- When you press a button, does it beep, or is there no response at all?
Those answers will help determine whether we’re dealing with a failed keypad, display board, or another control problem.
