Treefarmer
Suddenly, no spark to any of the burners. From looking at the diagram, it appears to me that the problem is with either the “valve switch” , also called the “interlock switch”, or with the spark module. What tests can I do to determine what part has failed?
The first thing I would do is check for 120 VAC to the unit.
If there is nothing wrong with the power supply and no one burner sparks, most likely the problem is a bad spark module.
Here are the breakdown diagrams and Replacement parts for AMANA PGT193UW Surface Unit - Gas | AppliancePartsPros.com
