Trash compactor not reversing
Brand:Jenn Air
Model Number:TC607X3
Main Symptom:Ram did not reverse
What happens & when:When the ram went down it did not reverse. It pushed down on the stops an flared both of them about a third up from the bottom. It also broke the drive gear and the screw drive rod on one side came up high enough to punch a hole in the top of the ram. I have checked the directional switch at the top and it checks good at all terminals. What is my next step. The motor runs without the drive gear.
Attached the tech sheet for your model with diagnostics and wiring diagram.
Follow the diagnostics until the issue is determined.
TechSheet-W10415490-RevA.pdf (307.1 KB)
