Tozser
How to replace front panel on dryer:confused:
Hello Tozer. First disconnect the power to the unit. Remove the lint filter, and the 2 screws under it. There are two clips in the front corners, release these clips with a flat blade, then lift the top of the dryer. Unplug the door switch, and remove the two screws on the inside of the panel at the top of the dryer. Pull the panel toward you and lift it off. Install the old parts on the new panel and reinstall in reverse order. Hope this helps.
