Touchscreen control stuck in a boot up loop
Brand: Kitchenaid
Model Number:koce900hss02
Main Symptom: boots to kitchenaid logo, then cycles and repeats
Error Code (if any): none
Parts or tests already tried: cycled power at the breaker, removed UI panel to ensure no visibly loose connections
Photos / video link: https://youtu.be/Bg4TDo-fCO4
That’s a logic failure within the hardware on the control panel W11396218. If the hard reset didn’t fix things then the control panel will need to be replaced.
https://www.appliancepartspros.com/whirlpool-console-w11396218-ap6983301.html
