Touch screen not connected
unit stopped showing clock ck and had power- had control bd repaired and fully ck out. when returned reinstalled and clock worked great but now no response from touchpanel.panel was responding as I could turn on lights and ever pb would beep when I pressed, now a F2- e1 code appears
See the attachment for your tech sheet.
Have you tried pushing the cancel button?
Have you tried unplugging the unit for a couple minutes to see if it will reset?
If yes to both the above then try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
KEBS207.pdf (378.7 KB)
cleaned cable -several times -still no response just same codes reset will not function.
The problem is either the keypad or the control board.
Unfortunately they do not publish the pin-out for the keypad so it is difficult to check it.
Since the keypad was OK before you had the board repaired then I would say that odds are that the control board is the problem but I do not know how the repair company checked the board out so this is just a guess.
Try checking the receptacle on the control board.
Could be it has a cold solder joint. Cold solder joints are often a duller silver color and/or have pin holes.
You could also try wiggling the connector while watching the solder side to see if any of the pins move in the solder.
A magnifying glass helps with the above.
Looks like the keypad is a sealed system so I do not think that you will be able to check the continuity of the individual tracks in the ribbon cable.
