123456789012345
Brand: acme
Model Number:
The top panel and the rear access panel can be removed from the washer to try to see if the leak is visible from either angle. Is the water dripping down from the frame? If it is, it’s always possible that the water may be coming from a different section. In a case like this, trying to follow the residual water trail can help identify a general location of where the leak might be originating.
