Brand: GE
Model Number: GTW330ask4ww
Main Symptom: vibrating /walking
What happens & when: any load ,setting, water level
Error Code (if any): n/a
Parts or tests already tried: bounce test on suspension rods
Brand: GE
Since the problem occurs on all loads and cycles, this points more toward a mechanical or installation issue than a load-balance problem.
Washer not level
Verify all 4 feet are firmly on the floor.
Rock the washer corner-to-corner; there should be no movement.
Re-level front-to-back and side-to-side. GE specifically requires all leveling legs to contact the floor firmly.
Suspension rods weak or damaged
Very common on this GE platform.
Worn suspension rods allow the tub to swing excessively and cause walking during spin.
This model uses suspension rod and spring assemblies to stabilize the tub.
Shipping material left installed
Floor issue
Open lid and push the basket/tub toward the rear and release.
Returns smoothly and centers itself → suspension likely OK.
Bounces several times, leans to one side, or feels loose → suspension rods are likely worn and should be replaced.
Does the vibration occur mainly during spin, or does it shake during wash/agitation too?
Approximate age of the washer?
Does the tub sit centered when empty, or does it lean to one side?
My current diagnosis based on the symptom description: 70% suspension rods, 20% leveling/floor issue, 10% other mechanical issue.
