Top Load Washer
The agitator doesnt move during any cycle enough to wash. However it does move slightly enough to see. Please help.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Reach in and try to turn the agitator by hand and if you can the agitator coupling is bad. Pull the agitator straight up and out once done you should see the agitator coupling try turning it by hand and if it will turn you have confirmed the coupling is bad, replace it. Clothes Washer Repair Guide[/COLOR][/SIZE][/FONT]
