Top display dead on dishwasher
Brand: GE
Model Number: GDT655SMJ0ES
Main Symptom: won’t start
What happens & when: The problem began when occasionally the dishwasher would not start. The breaker was shut off and turned back on and the dishwasher would run one time, but the next time it wouldn’t so the breaker was shut off again and eventually was left off overnight before the dishwasher would start. Eventually it just wouldn’t start at all. After troubleshooting and looking at the green light on the main control board, we surmised that we needed a new UI board. Ordered a new UI board from appliance parts pro.com and a door latch. After setting the pins and installation of both parts, when turning on the power source to the dishwasher, it made the beeping noise, but the lights on the top were not in the right place. Could not make any cycle selection (no lights) and when pressing the start button light came on above steam selection and lower wash area. Still would not start. Decided it must be the main control board, so ordered that one and installed. Put dishwasher back together, turned power on and still the same lights lit up and it would not start. Called Appliance pros, spoke to a Michael, who suggested we check the harness wire between the upper and lower boards. After checking the harness, it checked out. From here we do not know where to go. I called Appliance pros once again, spoke to Sally, who suggested that we join the forum page, make a post and see if we could get any satisfaction there. She suggested we may have to return the upper UI board as a warranty piece and get another one. If possible, would appreciate a phone call at [phone removed].
Parts or tests already tried: New UI board, door latch, and bottom control board
Photos / video link:\
