Hello. I have a Frigidaire electric range. The EIC board does nothing (no display, completely blank), bake and broil do not work, but the stove top burners work (but the LEDs for hot surface do not light).
I replaced the EIC board (twice!); that did not work. This model does not have a thermal breaker/fuse onboard.
I have element continuity, I have 240v at the terminal block and 240v outlet (2 120v legs, 1 neutral).
This seems to have occurred on the same day I had a new electric service panel installed, seems fishy, but I appear to have ok power at the outlet and terminal block.
I’m totally stumped. It’s like the EIC is not getting and sending anything 120v, but the 240v top burners are ok.
Ryan
