I Have a Ge Monogram Compactor. Right now when you hit run it is going down then keep cliking but not pullup, I have to turn off and hit run again to make it going up. What part that cause these problem. Please let me know so I can buy the part to fix it.
I open the swicth, there is 120V beetween Y and V, T-R and V. When I turn the switch to ON, there is no voltage beetween these switch. the motor lower the plate and it is not moving back up and keep ging a clicking noise, the knob is not turn back to OFF position. I have to manual to back to OFF and Then ON again so the motor can rising up to the top.
