To replace the stainless steel outer glass door (the glass cracked) do I have to remove the entire oven door. I was able to remove the damaged glass door while the inner door was still attached but I am having trouble installing the new one
Toby,
You do have to remove the door from the oven first. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEBS208DSS8 | AppliancePartsPros.com
Removing the oven door.pdf (167.6 KB)
Removing the oven door glass, hinges and handle.pdf (286.3 KB)
