To much water
My Maytag front loader washer recently got a bunch of holes in the bellow, so I replaced it. While watching the washer after the repair, I notice that the water was filling up the tub…it did not stop until it was half way up the door. With all the water in it, it was making the tub sink down which made the bellow expand and open up so the cloths are easily rubbing/spinning on the bellow…I’m afraid I’m going to rip another.
What is the issue with the washer?
Is it the water control level? If so, where is it? I looked at all the parts to the washer and could not find it.
Or is it the shocks not holding up the washer correctly?
BTW, the washer spins, drains, and works correctly.
Thanks for the help,
Bob
Parts for Maytag MHWE200XW00 Washer - AppliancePartsPros.com
It has info on overfill problems.
MHWE200.pdf (713.4 KB)
