Timr delay control not operating
When the timer delay button is pressed the lights do not come on to activate a timed wash cycle.
Could not find any info on the given model number, seems to be short several digits. Kenmore number are usually 3 digits, a period and then 8 digits.
Please check it.
Could be a dead key on the keyboard.
Check the other keys to make sure they all work. The keys often use a common line for about 3 keys.
The model number is 665.13744k601
It looks like a new control panel is needed here>
Replacement parts for KENMORE 66513744K601 | AppliancePartsPros.com
See the attachment for the tech sheets.
Could be the control panel (keypad) or the control board.
Only way to tell is to check the keys as shown in the tech sheet using a meter.
If you do see other keys that use the same ribbon cable tracks (wires) then it may just be a bad connection so I would try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
DU1055.pdf (251.2 KB)
