I have a whirlpool Super Capacity 465 with accubake system. If I set the gas range to bake it goes to pre-heat, & starts counting down from 10 min. during that 10min nothing happens, only when that 10min runs out the range fires??? If I set it to broil, it goes to pre-heat & fires within 5 to 10 seconds just like it should. It seems like some type of timing delay issue. Any suggestions on what is going on or what part I might need???
Most likely the problem is a bad oven Bake igniter.
- The Bake igniter AP6007756
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL SF385PEGQ3 | AppliancePartsPros.com
Thank you for such a quick responce. Just one more question before I purchase an oven bake igniter. during that pre-heat time the oven bake igniter is lit up, there is no smell of gas? Does the oven bake igniter control the input of gas as well?thanks
[QUOTE=955tavis;379908]…Does the oven bake igniter control the input of gas as well?..[/QUOTE]
Yes it does. You can find more information in one of our previous threads: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1897-oven-wont-lite.html
