Timer will not turn
Timer will not turn and heat comes on intermittingly.
Have replaced Timer switch, Cycling thermostat and Thermal fuse.
Is there anything else that can be causing my problem?
Probably faulty gas valve coils. Timer won’t advance in auto dry unless heat is cycling normally.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Eric
Eric:
Thank u for your suggestion. Have order replacement coils. I will let u know if that solves my problem
Kenny D
