Timebase and diagram
I’m trying to figure out what the time base and cycle duration is for this microwave to determine what the cycle interval is at the 10 power levels.
Also, I am looking for the wiring diagram or schematic for this microwave, I’m trying to wire an in-line variac to directly control the power level of the magnetron and not rely on timing cycles.
power 10 is 100% on, not sure I understand what your trying to do, but why don’t you just change the power level when you program the microwave to cook. Enlighten me :slight_smile:
When you change the power level on a microwave it is not actually lowering the output power, but instead cycles the power. So at 100% in a 1000W microwave, if you set it for 1min you will have 1000W irradiation for 1min. If you set it on 50%, you don’t have 500W irradiation for 1min, but rather, you have 1000W irradiation for 30 seconds, but divided into a cycled time interval (for example, 5 seconds on, 5 seconds off). I’m looking to wire a variac inline with the magnetron so as to directly control the power input so if I set the variac on 50% it will infact be 500W irradiation for 1min, instead of the 1000W cycling.
But i’m interested in knowing what the actual on-off time interval is for this specific microwave as well.
