Three beep error after pressing start on dishwasher
Brand:GE
Model Number:GDF570SGJ0WW
Main Symptom:Three beep error after pressing start button
What happens & when:Shut off circuit breaker for a day, the replaced door switch and main control board, after pressing start, it immediately goes into 3 beep error code.
Need help!
Error Code (if any): Three beeps after pressing start button
Parts or tests already tried: Door Switch and Main control board.
If the unit goes through the drain portion and then stops then check for a faulty water valve.
The GE dishwasher does not start after pressing the start button. It beeps three times, then start light flashes on and off repeatedly. I am not sure why you are referencing the water valve.
What is the three beep error code problem?
I was just trying to get an idea of if it tried to start at all. If it went through the drain but beeps 3 times then it could have been the valve. The fact that the unit beeps at the start, it sounds likely that it could be a console issue with the latch and the main board having been discontinued.
Ok.
I have verified water valve from sink to dishwasher is working. Disconnected the water line at the dishwasher, then turned on water valve and water came through hose.
I purchased Main Control Board from Appliance parts Pros. which I installed. when opening the box, the new Main Control Board was sitting outside the mylar bag, not in the bag. is there a chance the new board was already bad and being sold as new?
Is there a way to check Main Control Board?
Since the Main Control Board comes with a year warranty, should I request a new Main Control Board?
Is there a way to check the Control Panel?
also did a hard reset by turning off breaker to dishwasher, no change.
Steps Taken:
  1. replaced door latch/switch. it is engaging correctly.
  2. replaced Main Control Board.
  3. Verified water valve from sink is functioning. Water going to dishwasher.
  4. Control Lock is disabled or off.
