thin twin will not drain or spin it does agitate
I would check the lid switch for continuity with a multimeter.
I replaced the lid switch
Would have been helpful to know that bit of information in your first post. ![]()
Does the motor run during the drain or spin cycle?
Please give as much detail as you can.
hi sorry thanks for your help I checked
the machine last week and it was filling with water and agitating. gets to drain and spin and no motor sounds. Then it would not stop filling bad pressure switch? I have replaced the timer and the lid switch ordered new pressure switch
